shimming a distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2010, 05:00 PM
The mobile view is crap
This is a reply from OldBogie in another thread:
Milling the block, heads and intake can also play havoc with this as the vertical mounting dimensions of the distributor are affected which usually sets it too low and blocking of exposing the oil feed of the right side lifter galley by miss-positioning the groove in the lower boss of the distributor housing. For engine's that have been milled, it is necessary to shim the distributor to get the correct tooth engagement with the cam gear and to insure the oil groove centers around the oil passage.
how would one go about doing this correctly?
Old 11-11-2010, 05:10 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
I was told to put the yellow paint used to set up rear ends on the distributor gear, install the distributor, and rotate the motor a few times. The wear pattern should be in the middle of the teeth.
If at all possible, have the pan off and check for freeplay in the oil pump drive shaft. I've ruined a freshly rebuilt motor because I didn't realize it was binding.
Skip White 65,000 Volt Distributor Revealed Jr. Mechanic Engine 20 04-02-2015 05:00 PM
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
HEI Distributor Swap for a 4.3 knothead Engine 8 05-10-2010 02:27 PM
Distributor Drifting JamesRS Engine 4 08-18-2005 05:00 AM
