shimming spider gears make differential act like posi? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2005, 03:47 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I've read from a few sources that if you shim the spider gears up tight enough you can make an open differential act like it has limited slip. Has anyone one tried this or heard of it being done? How well did it work and how long did it last?
Russel
Old 08-15-2005, 06:33 PM
Jmark's Avatar
You cannot get the shims in to make it tight enough to act like a limited slip. If it did work, it would burn up the first time you spin up one tire on water or ice.
Old 08-15-2005, 08:11 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Shimming the spider gears in this way will only result in wearing them out.
If it does work, it WON'T for long.
Looking at new gears and posi. Novaman78 Transmission - Rearend 5 01-17-2005 08:37 PM
Posi Rear end gears 1968rallysportcamaro Transmission - Rearend 1 02-18-2003 02:52 PM
12 bolt spider gears question 85406 Transmission - Rearend 2 11-28-2002 04:59 PM
Posi Gears ElCoKid Engine 9 09-26-2002 10:13 AM
what gears? how to make it a posi? bildo95 Transmission - Rearend 6 08-31-2002 05:41 PM
