Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - shimmy in suspension
Old 04-29-2010, 08:59 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
Originally Posted by elcaminoman69
well i didnt do any thing to the front end only the rear suspension. when i took the car apart it never did it. but the back end of the car sits higher now so could that maybe affect the caster?
Yes, it will. So will worn front end parts combined with new tight rear suspension parts.
Could also be a driveshft vibe from the pinion angle being wrong as Cole has suggested. Did you verify the angle when you swapped to the ladder bar suspension??
What ladder bars did you use ?? The bolt-on ones sold by Lakewood and Competition Engineering that also bolt to the stock suspension and housing( these are terrible for traction by the way, all they do is bind up the suspension so it can't move) or Full on Drag chassis ladder bars??
