shimmy in suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2010, 04:00 PM
elcaminoman69's Avatar
i have just restently built a 1979 elcamino and i put a whole new suspension and drive train in it. i built ladder bars and put coil over shocks on it. the problem is when im slowin down i can feel a bad vibration threw the steerin wheel and the floor. and i even put it into nutral and it still did it. i dont know where it could be comin from. i have a posi diff. in it also.
Old 04-28-2010, 04:32 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
And you only feel it when you are slowing down that's it? You don't feel it when you are taking off at all?
Cole
Old 04-29-2010, 07:22 AM
no only when i slow down. i put the transmision in neutral and it still did it.
Old 04-29-2010, 07:51 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Having some past experience with something similar, I would look at the front end alignment first. Had a car which did this when I was decelerating. The caster was more negative than it should have been, so when the weight transferred to the front end because of the deceleration, that was enough to start an oscillation due to not enough caster. Also, incorrect toe setting could start a sequence of events that would be similar to what you are seeing.
Old 04-29-2010, 01:24 PM
well i didnt do any thing to the front end only the rear suspension. when i took the car apart it never did it. but the back end of the car sits higher now so could that maybe affect the caster?
Old 04-29-2010, 04:47 PM
eloc431962's Avatar
Wiki Edits: 37
Did you change the angle (pinion)of the rearend at all during the changes you made?
Cole
Old 04-29-2010, 09:59 PM
ericnova72's Avatar
More for Less Racer
Yes, it will. So will worn front end parts combined with new tight rear suspension parts.
Could also be a driveshft vibe from the pinion angle being wrong as Cole has suggested. Did you verify the angle when you swapped to the ladder bar suspension??
What ladder bars did you use ?? The bolt-on ones sold by Lakewood and Competition Engineering that also bolt to the stock suspension and housing( these are terrible for traction by the way, all they do is bind up the suspension so it can't move) or Full on Drag chassis ladder bars??
Powder-coating the suspension - ?? hd_rider Suspension - Brakes - Steering 3 09-29-2008 05:55 PM
Narrowing a '73 GM B-body Front and Rear Suspension hduff Suspension - Brakes - Steering 2 09-09-2007 09:56 AM
1979 F250 Suspension MrCoolDale Suspension - Brakes - Steering 1 07-20-2007 08:05 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 07:29 PM
how to hang a C- 4 suspension ? Redmist Suspension - Brakes - Steering 1 12-31-2004 12:48 PM
