Shock Angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2007, 02:18 PM
Thirty Seven Ply's Avatar
Shock Angle
Hi,
I'm ready to mount the rear shocks in my 37 Plymouth which has leaf springs.
What angle should they be set at? They are standard street rod shocks from Posies.
Thanks, Barry
Old 04-24-2007, 03:03 PM
mosstrooper's Avatar
If you do a search you will find many articles here which discuss this matter. To put it simply, the bigger the angle, the less effective they will be. The shocks are rated to be set in the vertical position, any angle will reduce that rating.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 09:02 PM
shock angle formula hot34coupe Suspension - Brakes - Steering 4 01-21-2007 02:23 PM
shock angle? kmodel52 Suspension - Brakes - Steering 2 01-28-2006 07:22 PM
Optimum rear shock angle jpd37 Suspension - Brakes - Steering 42 05-24-2005 04:55 PM
rear shock angle zonk Suspension - Brakes - Steering 8 04-14-2005 08:11 AM
