shock angle formula - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2007, 07:26 PM
shock angle formula
Does anyone know a formula for calculating spring rate change for coilover shocks when the shock is angled in at the top? Example 200 lb. spring rate in a 90 degree (straight up) position then angled in toward the centerof the car by 30 degrees. Inquiring minds would like to know.
Thanks,
Hot34coupe
Old 01-20-2007, 08:16 PM
powerrodsmike's Avatar
Wiki Edits: 161
Here is a calculator:
http://www.proshocks.com/calcs/anglefirst.htm
BE different....ACT normal.
Old 01-20-2007, 10:33 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
powerrodsmike - Thanks for the link!
Old 01-21-2007, 05:47 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
If you misplace the URL for that calculator, you can divide your desired rate by the square of the cosine of the angle.
Old 01-21-2007, 02:23 PM
home brew's Avatar
Billy I love it when you talk dirty!
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 32 05-11-2007 07:22 PM
Shock Angle Calculation Spreadsheet Wesley J Suspension - Brakes - Steering 0 01-16-2007 09:56 AM
shock angle? kmodel52 Suspension - Brakes - Steering 2 01-28-2006 07:22 PM
Optimum rear shock angle jpd37 Suspension - Brakes - Steering 42 05-24-2005 04:55 PM
rear shock angle zonk Suspension - Brakes - Steering 8 04-14-2005 08:11 AM
