Shock installation on 1968 C10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2006, 04:49 PM
WEll I think I screwed this one up! I installed Doetsch 4052G shocks on the front of my '68 C10. The old shocks had no inserts in the rubber so I assumed that I didn't need any for the new shocks. Well I have about ruined the polyurethane mounts.
It's obvious that this isn't the way to install shocks. How are the shocks properly mounted?
Old 08-30-2006, 11:58 PM
Are you sure you have the correct shocks ???
Old 08-31-2006, 12:46 PM
OK I think I got this resolved. I checked with a guy that has an original '68 and upon checking his truck found that the brackets on mine had been modified! I corrected the brackets and the crush sleeves that came with the shocks fit perfectly. The shocks with the crush sleeves installed fit and operate fine.
Why I would think that some previous owner knew what he was doing is beyond me. I won't make that mistake again - especially with the help available here.
Thanks
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Rear Shock Placement, Angles ZipZ28 Suspension - Brakes - Steering 22 10-08-2005 02:52 PM
Shock compression at installation? Arcuden Suspension - Brakes - Steering 3 08-24-2005 05:30 AM
Lever Shock is in the way! rwruther Suspension - Brakes - Steering 0 06-11-2004 03:20 PM
