Which shock installation design? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2010, 12:37 PM
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Okay, i have been measuring on the rear of my truck and i just can't make up my mind. In the first picture you can see how i am thinking about mounting my shocks inside the frame, but my concern there is that i don't have allot of tube. The axle tube is actually outside of the frame, so i would have to basically mount the shock bracket to the housing.
Second picture you can see using the original axle lower shock bolt, i can build a bracket off of the Frame box and install a shock there. My concern there is the fact that i am not sure if that is a safe location or how well the shock will work there.
So what are your thoughts from looking at the images? Mount the shocks inside or outside the frame rails?
ID:	48448   Click image for larger version
Old 09-27-2010, 01:37 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would go outside in this case..
Sam
Old 09-27-2010, 01:51 PM
The more vertical the mounting, the more effective the shock is.
Old 09-27-2010, 04:00 PM
ericnova72's Avatar
More for Less Racer
I would go outside also, the closer they are to the wheel the more effective they are. True vertical is the best mounting angle, as Joe stated, so don't angle them any more than needed to fit them into a space. If you do build a crossmember and put them inside the frame, put them as far apart as you can, you could actually mount them off a boxed section of the frame like your outside pic is and not need the crossmember.
Old 09-27-2010, 05:00 PM
car enthusiast
Outside it is. I ordered a set of shocks for it today, hopefully i picked the right size. From the middle of the shock bolt on the axle to the center of where i will mount the top of the shock will be 10 inches. So i ordered a shock with 8.625 compressed and 12.75 extended. I took the 10 inch measurement with weight on the rear of the truck, thinking my body weight plus a full tank of gas. It's not going to haul anything other then ***.....
Old 09-28-2010, 05:05 PM
car enthusiast
Here it is all welded up and shocks installed.......the shock measurement is awesome...have roughly 2" of travel each way.
ID:	48477   Click image for larger version
ID:	48478   Click image for larger version
ID:	48479   Click image for larger version
ID:	48480   Click image for larger version
Old 09-28-2010, 05:18 PM
car enthusiast
Here is a before picture:
Shock Design 70bird Suspension - Brakes - Steering 3 02-03-2008 03:21 PM
Design problem with front shock mounts rwruther Suspension - Brakes - Steering 1 04-25-2007 07:38 PM
Shock installation on 1968 C10 68chevytrkr Suspension - Brakes - Steering 2 08-31-2006 11:46 AM
Shock compression at installation? Arcuden Suspension - Brakes - Steering 3 08-24-2005 04:30 AM
Engine design school willys36@aol.com General Rodding Tech 1 08-14-2003 01:42 PM
