Shock Mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2005, 08:29 AM
loiselle's Avatar
Shock Mounts
I have a Model A with 350/350. I have a Mr. Roadster 4" dropped tube axle with hair pins. There are no spring perches. I am looking for suggestions on lower shock mounts. Has anyone used friction shocks or lever shocks on a setup like this? If you used tube shocks, what did you use for lower shock mounts?
Thanks.
Larry Loiselle
ditvenet@hotmail.com
[Be Righteous Not Politically Correct]
Old 05-09-2005, 09:03 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
ya need
To go here This place they have all the pieces that you need to install a Mr.Roadster axle in your rod..
OMT
Rear Shock Mounts olsen2544 Suspension - Brakes - Steering 3 04-10-2005 05:06 PM
can i change my shock mounts around. scotts82 Suspension - Brakes - Steering 2 03-04-2004 12:19 PM
rearend shock mounts johnnymopar Suspension - Brakes - Steering 1 03-01-2004 03:20 PM
front shock mounts 33 Forf P/U homer Suspension - Brakes - Steering 0 10-29-2003 10:36 AM
Front shock mounts homer Suspension - Brakes - Steering 1 10-29-2003 09:11 AM
