Before you do that, what are your plans for suspension when they are removed?
Plus, have you thought about the structural strength of the body?
Ontario Rodders |
He stated in a previous post that he had bought a conversion kit from Speedway Motors, but had not bought the x-member yet. He did not state the vendor of the kit, but I would assume that it came with detailed instructions and the replacement panel for the tower.
That apron had to hold a lot of weight Facon 5.0, so it will be a little tough to cut out of there.
This is what he asked; Quote:
Something like this sounds fairly easy until you are the one with the panel cutter. I come here to share knowledge, not let my ego get the best of me. And you? |
Actually this kit came with no instructions whatso ever. Because i made the consciece decesion to build the crossmember myself and their was no affordable kit for that car so i ordered all the parts i needed minus the crossmember.
Since the kit is very similar to what was offered stock on the MII mustangs i will get measurements off my friends Buick that has a similar setup. i got the towers off now and will cut a template to build a panel to fill in the space that i cut out. and will brace the frame upwards with a tube design including a new tube export brace that i may run through the firewall later to a potential roll cage but for now i will just plate it on the other side. But yea poncho it is an MII kit from speedway motors came with control arms springs shocks brake kit everything except the Xmember and spring cups |
I may be wrong, but I believe that car was a uni-body type, like the Mustang. If so, the lower frame rails are not very thick or strong. Probably not strong enough to support the MII type spring cups without some serious reinforcement. Have you considered trying it with an original crossmember? That way the spring cup is part of the crossmember, and does not have to be welded on separate. If the width would work, you still might want to reinforce the frame rails.
Just a suggestion. |
Here are some written instructions...
-Street Rod Engineering- ...that might help you along. Rod & Custom Motorsports has a highly detailed written instructions and photographs with theirs. |
Kultulz, thanks for that website it will definatly help and also thanks for being with me just about every step of the way i alway value your input
Adkart yea your right it is a unibody type frame and if by original crossmember you mean the one that came stock i cant use it because i unbolted it and removed all the bracketry with it (it was built in with the shock tower) I thought about bracing the frame with some panels welded alongside the stock frame rails but i was afraid generating that kind of heat while welding would only weaken it any ways...Opinions? One more question. Should i remove the stock strut rod mounts an brace the front another way or if their is no space conflict just leave them their. Because those instructions say to clear the framerails 6inches either way and i think that old bacetry is within that radius and will not be used on the new struts since the MII kit faces the opposite direction |
Any chance of your letting it sit for a couple of days? I wish you could get a copy of Rod & Custom Motorsports catalog as when I got mine (several years ago) it included a magazine article fully detailing what you are doing. They cut the page size so the magazine publisher is not shown but I bet that they are still available. If nothing else, I will copy this one and mail it to you.
Might save you some time and cussing...
kultulz,
Well i think your right, if your willing to copy that article i would be more than gracious. Does it give all necessary measurments because that is the big one i need. metalman300h@hotmail.com also is their a way to predetermine the ride height with the spring i have befor i set the suspension in their and build the spring hats Last edited by 5.0Falcon; 02-25-2004 at 07:32 PM. |
