shock travel - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2004, 07:27 PM
play with fire
shock travel
Hey guys - Does anyone know how much a shock should be pre-loaded, as far as a percentage of travel? In other words, how much should the shock be compressed when the suspension is at rest? I'm ready to weld the lower shock mounts to the axle housing, and I need to figure out the correct angle. Any help would be appreciated.
66 GMC half-ton, 461ci,700R4,4/5 drop
Old 12-16-2004, 09:05 PM
poncho62's Avatar
Wiki Edits: 5
I would hang the suspension down with stands and give the shock a little more travel than that. Just the way I would do it.
Old 12-16-2004, 09:14 PM
play with fire
That is a great idea! Makes sense! Thanks for the advice.
