Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is shop air safe for a fresh air breathing system?
Old 02-24-2012, 09:30 PM
TucsonJay's Avatar
TucsonJay TucsonJay is online now
I was asking the same question, and found out that "oil-type" air compressors produce carbom monoxide.... because there is oil in the cylinder during compression.
You would need to use a diaphram-type, also known as "oiless" compressors. I switched over, and now do what you were talking about. I will add that they are not inside the booth sucking paint fumes. :-)
