shop electrical problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 06:06 PM
Hope someone with some electrical experience can help me out. Wired a bunch of flourescent liht fixtures up in series. When i hooked it all up i seem to have power going into my ground wire? I have checked connections everywhere it all seems to be wired correctly the rest of my shop is fine its just this one series of lights and it happens to be the one with the most lights on it like 20. The only thing i can think of is i put a screw through a wire when hanging the fixtures. Would that cause this to happen? This is driving me nuts no wires touching anywhere i cant find the problem? Any help would really be appreciated> thanks
Old 01-27-2006, 07:36 PM
willys36@aol.com's Avatar
Wiki Edits: 21
You mean you hooked them up in parallel I hope! Anyway, it sure sounds like you did cross wires somewhere and the only way to find that type of problem is start disconnecting the lights one-by-one and trying the circuit until you isolate the bad puppy. I too just finished installing shop lights (28 4'ers). Instead of hard wiring them to the feed wire, I wired the ceiling with regular old two-plug wall sockets in a row down the middle of the ceiling. Then all I had to do was hang the lights, one on either side of the wall socket, and plug it into the socket. Much easier to trouble shoot. Once my sockets proved OK, the lights had to work.
Old 01-27-2006, 08:07 PM
Yes i'm thinking there is something crossed i've gone one by one and i hit the spot where my problems start. Unfortunately i think the problem is in the ceiling thats going to be a blast just had insulation blown in a while back going to try to see if i can somehow bypass this light but its still hard to pin point the exact light. I had to move some to make room for my garage doors so i used junction boxes up in the ceiling. But the one wire that seems to cause the problem when hooked up seems to just be a straight wire from one light to another i dont understand how that one could cause the problem? I think i may have no choice but to climb in the attic and check it out.
Old 01-31-2006, 05:51 AM
I'm an electrician by trade. I'm a little confused at how you know the power is going through the ground? Could you be a little more specific on exactly what is happening?
Old 01-31-2006, 10:14 AM
well if you feel a ground wire is some of the fixture theres definately cureent going through there. i traced it back from the start to where i started having problems and found the wire that was the problem. seems like a cable strap pinched the wire its all fine now. thanks
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
Hotrodders Knowledge Base: Electrical Jon Electrical 0 11-26-2005 06:41 PM
Small shop / electrical help. smoke Garage - Tools 54 09-26-2005 08:52 PM
Will this be a problem for my electrical system? subman17 Electrical 4 02-13-2005 09:12 PM
hey everyone! electrical problem! Help please! 74duster Electrical 6 04-29-2004 11:58 PM
