Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Shop floor
Thread: Shop floor
  #23 (permalink)
Old 02-06-2010, 08:59 PM
Old Fool's Avatar
Old Fool Old Fool is offline
Great job!
What is the r factor of the foam you used?
When you get ready to run the system, cut the glycol back to 30 %, you will still have adequate freeze protection and have a higher heat transfer efficiency.
Check out Munchkin boilers.
Taco makes a good circuit setter for the money.
Make sure your expansion tank is for glycol and not for potable water
