Shop floor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2010, 03:13 PM
Semper Gumby
Wiki Edits: 2
Shop floor
WARNING! WARNING! Horrible puns ahead!
After a couple of years of having my 40X60 shop with only a dirt floor - I finally did it. Smooth. level. compacted sand, vapour (vapor to our US cousins!) barrier, 5 inch Hi density styrofoam, mesh plus rebar, and then lay in the PEX tubing for hydronic floor heat.
Then last Saturday, 5 and a half inches of 34 MPA concrete, with fibreglass strands mixed in, laid in, and machine finished and polished.
I was just "floored" by the amount of "concrete progress" and "mortarfied" that I hadn't done it sooner!
(I warned you!)
Old 02-02-2010, 03:34 PM
wretched ratchet's Avatar
one full turn after it squeeks
This post is usless without pics - - - -
Old 02-02-2010, 04:06 PM
302 Z28's Avatar
Absolutely.
Vince
Old 02-02-2010, 04:41 PM
Semper Gumby
Wiki Edits: 2
Pix of shop floor
Now- just as soon as I can get my pix downsized from the current size to something that will attach, I'll even post 'em!
I had tried - a couple of shots of the floor with the pipes & styro showing (pre-adding re-bar) and a couple of the concrete pumpers etc, and a couple of the finished product
And every single one then said "file too large"
Old 02-02-2010, 04:49 PM
Looking forward to seeing that project, for sure, if you are using Photobucket, it will downsize them for you !
Old 02-02-2010, 05:13 PM
Semper Gumby
Wiki Edits: 2
pix
OK - I'll try again
ID:	43644   Click image for larger version
ID:	43645   Click image for larger version
Old 02-02-2010, 05:38 PM
WOW, I am throughly impressed - - - nice stuff, Dave
Old 02-03-2010, 07:36 AM
302 Z28's Avatar
Man that is going to e one nice shop...congratulations and nice job.
Vince
Old 02-03-2010, 07:58 AM
OLNOLAN's Avatar
I Can't Believe !
Dave, I can't believe you're finishing up MY dream shop. How dare you! With floor heat! Who do you think you are? You ain't right! That was MY idea! Can't believe you're doing this to me! Getting yours finished while mine is still a dream just ain't fair! You stole my plans! Now I guess you're gonna fill it with cool hotrods and stuff! The nerve of some people! YADA,YADA,YADA olnolan
Old 02-03-2010, 08:14 AM
boatbob2
Daves garage.
Hi Dave,very nice job !!! what do you use,to heat the water for the floor? i live in north florida,so,im just curious..
Old 02-03-2010, 08:30 PM
Semper Gumby
Wiki Edits: 2
heating the floor
Well so far what I am using is - well - nothing.
HOWEVER long range (like maybe next year?) plans call for a small, hi-efficiency natural-gas fired boiler, with pumps, an expansion tank, valves, manifolds to distribute the hot water among the various loops, and manifolds to collect the cooler return water for it go back into the boiler. Valves to regulate how much hot water goes through each loop, etc. An Air/water separator is crucial.
The system is full of a 50/50 mix of Prestone automotive anti-freeze and water, and pressure-tested to 175 lb BEFORE I poured the concrete - leaks are never a good plan INSIDE the slab!
Old 02-04-2010, 12:09 AM
Im trying to have an idea!
very nice. enjoy that pex
Old 02-04-2010, 04:32 AM
dinger's Avatar
Verrrrry nice! Now if you lived in Ca. you could use solar to heat that water...but then you wouldn't need the heat...never mind, it's early and I just ain't the brightest shop light in that shop this early.....I'll be up next January to help with the latest project.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-04-2010, 06:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Looks Great!
Does the floor have expansion joints or whatever you call them between the different segments? Or does having floor heat do away w/that?
And how did you (or did you even need to) 'grade' the slab for drainage, or is there a central drain, or? I know I will need to because it's outside.
Reason I ask, is I'd like to someday redo the shop's surrounding slab, and am obviously clueless.
Thanks.
Old 02-04-2010, 07:28 AM
Wiki Edits: 27
you did it right.
I wish I had done the pex for radiant heat for my 40 X 60 shop on the working end. I have big woodstove and I was using the backhoe bucket or 2 load of firewood each day. And it would just thaw you out a little bit. I was spending the winters working in sunny Calif and forgot what 40 below was like up here. I don't know if it is efficient enough but some people have used solar heat on the cloudy Oregon coast to heat water to 70 degrees then a heat exchanger to bring the floor loop temp higher.
Designing New Garage roger1 Garage - Tools 247 03-30-2013 05:48 PM
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-18-2010 11:19 PM
looking for info on opening a shop in a small town rb8179 Hotrodders' Lounge 15 02-25-2006 05:03 PM
starting the floor modas Body - Exterior 1 07-17-2005 06:39 PM
Once again.....JOKE TIME!!!! RCastle Hotrodders' Lounge 41 01-21-2005 01:27 PM
