Well heat rises so maybe you need to fab something up to allow you to mount them a few inches lower.
I'm using a propane heater in my garage
Like Henry says, since heat rises, I would mount them as low as possible. A ceiling fan would help get the air down where you want it too.
Ontario Rodders |
Get a sheet of metal 22 or 20ga. and screw it to the ceiling. I screwed one end to the ceiling and bent it at a 45 and ran some shrt chains to the other end. Help direct the heat downward too.
Since it was mounted according to the directions, using the only mounting brackets supplied, I felt that it was where it should be. Atleast how it was designed to be used. I am now going to make a heat shield out of some aluminum that I have, and attach it to the mounting bracket to reflect some of the heat away from the ceiling. Since I do paint in that room, I want to keep it as clean as possible, with as few areas for dust to collect as I can get away with.
I now get my main heat from one of those radiator type, oil filled heaters that Barryk suggested a while back. I also have a kerosene heater that I use in the other room, so there is other heat available. Aaron |
Aaron,
WHAT, prey tell, are you doing READING the instructions? Those books are only there for packaging.... |
Use a metal sheet where the heat damage is, use 1 inch spacers between the metal (or any non combustible material) and the ceiling so there is a 1 inch air gap between the ceiling (or wall, for that matter)and the shield and clearance to combustibles becomes next to nothing. I would use a piece about 6 inches larger than the heater for the shield. Pyrolysis can become a concern after a period of time. Dan
| Recent Garage - Tools posts with photos |
| Leaving your car at an Upholstery shop?? | HotRodMan | Interior | 7 | 12-13-2005 07:13 PM |
| Choke heat tubes - how important? | cboy | Engine | 2 | 05-11-2005 06:34 PM |
| Chrome water pump | 49dream | Engine | 12 | 11-16-2004 05:17 PM |
| Scenes from my shop. | willys36@aol.com | Garage - Tools | 45 | 09-11-2004 10:46 PM |
| San Francisco Area Paint Shop | billcar670 | Body - Exterior | 3 | 10-24-2002 05:33 PM |
