Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Shop press questions. Making one.
Old 11-24-2012, 05:44 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Originally Posted by silentpoet View Post
I have decided to make a small shop press. I have a 4 ton jack that I can use for my press. I know it is not super powerful, but better than nothing. But will it be enough to press the bearings in and out on my 2003 pt cruiser. That is the current job I am needing it for. I have all or almost everything I need to make it onhand. I might have a slightly bigger jack someplace, but the 4 ton was all I could find in the basement where most of my tools and junk are. After thinking about it the 4 ton is probably the bigger one.
The other main question is about the ram end of the press. I am not sure what sort of profile I need to have on the business end.
I would go with an 8-10 ton jack as these wheel bearings can be a B#*#*ch. to break loose and the bearing usually explodes. At least here in the rust belt.
My press at home is made from the channel steel of a mobile home hitch.
Must commercial press use a plain large 1 1/4" or larger stud that uses slip over set screw attachments.
I have two large crates next to the press full of old shafts, bearing races, plates and shapes. All make good press tools.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
silentpoet (11-24-2012)
