Shop tip welding - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2007, 09:59 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Shop tip welding
Every now and then just by dumb luck I stumble onto a neat trick, and I have one for the welders... All my welding magnets had metal filings all over them. This can not be helped, however try this one on. It so simple it is stupid, just take a blow gun or blow tip with about 60/90 psi and blow off those little hitchhikers.......... I was amazed it cleaned the magnets completely.............. maybe I am late to this table, but from some of the pictures I see this tip might come in handy, just my $0.02
Old 01-15-2007, 12:14 PM
I cut shim stock to lay between the magnet and metal, then just pull the stock and the magnet stays clean.
Old 01-15-2007, 05:17 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Silly me, I usually just use a shop-vac with a brush to clean em
Old 01-27-2007, 03:29 PM
ict55chevy's Avatar
blow or no blow
also when not in use , a zip bag to keep them clean, and under the weld table.
Old 01-30-2007, 05:29 PM
Shop tip welding
Try using the magnets while inside a zip lock bag. When you're done turn the bag inside out, retrieve the clean magnet and dispose of the bag and filings.
Okay,It's Not Eye-Candy...But,It Could Be Used For An Inexpensive Shop nightrain_rod Garage - Tools 76 04-20-2006 11:19 AM
Which welding techniques do you use most in your shop? kringold General Rodding Tech 64 02-22-2006 11:11 PM
'Dream Shop' nightrain_rod Garage - Tools 24 01-06-2006 02:07 PM
shop air flow olsixrod Garage - Tools 2 04-06-2005 07:41 PM
introduce me too welding tony7 Hotrodding Basics 5 11-19-2003 02:43 PM
