shopline paint mixing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2007, 10:44 PM
well i have a few ? first i can't find what raio to mix my paint here is what i have help please.
it is shopline paint
jbpb acrylic basecoat /gallon
jc620 acrylic urethane clear /gallon
jh6265 fast hardner/guart
jp202 2k primer surfacer/gallon
jh301 2k undercoat hardener/quart
jr506 meduim reducer/gal
the paint shop said this is all i need to repaint my truck/color change/
last i new you mixed reducer with primer not hardener?
an no reducer for the clear? I can't find any thing on the web please help
Old 06-22-2007, 12:42 AM
Countilaw's Avatar
Cox Custom Cars
jbpb base coat is reduced as needed with jr506
From the looks of it, jc620 Clear is mixed 4:1 with jh6265 fast hardner
jp202 is mixed 4:1 with jh301 hardener
Depending on the temperature in MI, if it is over 75 degrees, I would take the Fast Hardener back and get a Medium or Slow hardener.
With the fast you will run into a major orange peel situation. The slower hardener will allow the clear to flow out better.
Frank
Old 06-22-2007, 07:41 AM
thanks i am taking back the fast hardener @80+ degress outside it will dry before it hits the truck. i just need to find the mix ratio foe the base
The paint did not harden powerrodsmike Body - Exterior 27 03-05-2009 06:34 PM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 03:20 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 01:18 PM
Basic of Basics - Choosing a color Centerline Body - Exterior 1 11-26-2005 10:12 PM
