shopline for painting a patch panel - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2011, 12:06 PM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
As some of you may have read my last few posts, I've started the painting process on my 92 miata practice car. I weekend in a patch panel and now I need to blend with the factory paint that I didn't remove. Seems like a lot of people say not use shopline for panels that you have to blend. Wondering, what you all think of this and maybe I should step up to a better paint? Its just a daily driver/commuter car but I like to do things right...
Old 07-21-2011, 01:18 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Mainly it is in how good a color match you can get. guys in the collision shops swear by what ever they have on their mixing banks that give them a good result. the shop I work with has PPG tints and toners on the mix bank and gets good results on match. If you order by color code from an online supplier it may be just right or a shade off..Ok for an all over but not so good for a blend for a fussy customer. Either way you just have to take your chances when you are working at home..
Sam
Old 07-21-2011, 03:50 PM
Mach1460's Avatar
I decided to go with the shopline, since this is my first real "complete" start to finish on my own with bodywork and painting i figured ill learn something either way. Ill post some picture when I get it sprayed. Thanks for your insight!
Old 07-26-2011, 08:22 AM
I just used the Shopline system to fix my rocker & cab corner. I wasnt looking for "Collision Shop Quality"...just something that looks better then rusted panels on my beater and even just using a the Single Stage Urethane, I was impressed at the matching..it exceeded my expectations.
Old 07-26-2011, 09:59 AM
Mach1460's Avatar
Good to hear, I also am not looking for a showroom finish, its a daily driver/practice car. I'm just about ready for color so ill post some pics soon.
First Time Sprayer, problem with Practice Panel, PPG Shopline cvpi Body - Exterior 35 06-08-2011 06:42 PM
First time patch panel job Blazin_Jason Body - Exterior 8 10-13-2009 09:46 AM
patch panel/weld help old trucke Body - Exterior 1 09-23-2009 02:57 PM
Patch Panel bobstoll Hotrodding Basics 3 08-25-2009 03:38 PM
patch panel for f-100 qckshftn56 Body - Exterior 2 02-26-2004 06:27 PM
