Short Block help
Need some info for a good combo that will be in my 57 gmc. Truck weighs 4200# with a full tank of gas and me in it. Running th400 with 12 bolt truck 411 gears, 29 inch tires. I have already ordered a profler 195 set of heads. 64cc with 650 roller springs. So far that's all I have ordered. What are yalls thoughts abut a short block build that would have at least 400# of torque and somewhere about 400 horses? I do want a roller cam. Howard's cam rep recommended a 110265-12. I prefer either an isky or howard's camshaft. I personally don't see it on a drag strip. At least with me in it. This pickup will eventually end up being my oldest daughter's. So dependability and running on around 91 octane is a factor.
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
nthogdog (02-28-2013) | ||
With the weight of the truck gearing,tire size a 406 would be a great engine with lots of torque and good horsepower will work good with th400 with those 64 cc heads you need dish pistons,dont forget to drill steam holes in heads for 400 block,.when and if you give it to your daughter you can install a rev limiter and or ajustable throttle stop, Ben there done that,
The 420 would be the most practical in a dart block.I have a 434 in my car,it makes torque,quite a lot actually.You pick the size,,,??? 420 is 4.155 bore x 3.875 stroke
434 is 4.155 bore and 4.o stroke 398= 3.62 stroke and 4.185 bore( very fast revving) 377= 3.48 strokex4.155 bore ( very fast revving) 352= 3.25 strokex 4.155 bore (crazy,nascar style revving) |
I second the 5.3 Ls. Especially if you're giving it to you daughter. Gotta love fuel injection.
Otherwise just build a basic 383. Good set of heads, 9.5:1 compression and a mild cam for torque. Plus you can run on 87 octane with that compression. |
| The Following User Says Thank You to bigdog7373 For This Useful Post: | ||
Its all about budget. crower rods,callies cranks etc are higher quality items.manley severe duty valves Vs chinese 2 piece valves,they start out as 1 piece valves
It's a GMC! Put a Pontiac in it so it "looks right" and will drag that small block backwards down the street... (:- I always liked those trucks. Wanted a '59 since high school, when a girl I was "chasing" had her dad's with a 370 and 4-speed "Hydro" in it. Stock as a rock, and a VERY strong runner.
In any case, build for torque and low-speed power, due to the weight. Jim |
| The Following User Says Thank You to Mr. P-Body For This Useful Post: | ||
nthogdog (03-01-2013) | ||
another thought,if you just want a nasty mouse(mild build) use a dart tall deck and build a 472
thats 4.200 bore and 4.25 stroke with moderate 200 cc heads and a hydraulic roller cam you could get close to 600 pounds torque and same with hp even the pontiac guys would like that |
thanks! |
The Howard's stuff is very very nice pc's for what you pay for and what you get:
Thanks, I just happened to venture off into the howard's stuff and found the crankshafts. Now I know they are a very good quality piece!
| Long Block Vs. Short Block | chevy53 | Engine | 6 | 04-11-2013 06:59 AM |
| Long block short block fitted block what do | opelitis5 | Hotrodding Basics | 4 | 01-10-2010 06:12 PM |
| Need advise for trade. 408 short block for dart iron eagle block | sherman8r | Engine | 6 | 12-06-2009 04:37 PM |
| Lookin for a ************** short block or long block | Jarod Lee | Introduce Yourself | 2 | 09-24-2009 05:25 PM |
| short block, long block | astrops | Engine | 5 | 04-11-2004 08:14 PM |
