Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - short block, long block
Old 04-11-2004, 07:29 PM
Rhansen's Avatar
Rhansen Rhansen is offline
Footbraker
Originally posted by Ktaves1971
You need to measure your block to see if it is a short or long block, A short block is 4 inches shorter than a long block. Do not go with a short block! It means somebody has cut off the back two cylinders! Not a healthy engine anymore at all.
Then you would want a 3/4 cam (12 lobes) to go with that short block.
