short block, long block
Might be a dumb question, but what is the diff between a long block and a short block.
Thanks |
Short block comes without heads. Long blocks come with heads and sometimes a intake, depending on who you get it from.
You need to measure your block to see if it is a short or long block, A short block is 4 inches shorter than a long block. Do not go with a short block! It means somebody has cut off the back two cylinders! Not a healthy engine anymore at all.:pimp:
You're too much!! ;)
DoubleVision said it all.... If you need more help, just ask... Rick |
Dont forget an order of fries. HG:P
| All times are GMT -6. The time now is 01:00 PM. |
