short block, long block - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2004, 02:27 PM
astrops's Avatar
Might be a dumb question, but what is the diff between a long block and a short block.
Thanks
Old 04-10-2004, 03:28 PM
DoubleVision's Avatar
Short block comes without heads. Long blocks come with heads and sometimes a intake, depending on who you get it from.
Old 04-11-2004, 02:11 AM
You need to measure your block to see if it is a short or long block, A short block is 4 inches shorter than a long block. Do not go with a short block! It means somebody has cut off the back two cylinders! Not a healthy engine anymore at all.
Old 04-11-2004, 04:28 PM
You're too much!!
DoubleVision said it all.... If you need more help, just ask...
Rick
Old 04-11-2004, 06:29 PM
Rhansen's Avatar
Footbraker
Then you would want a 3/4 cam (12 lobes) to go with that short block.
Old 04-11-2004, 08:14 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Dont forget an order of fries. HG
