Short In Charging System? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2005, 05:30 PM
I have a '94 Mitsubishi Mighty Max, 2.4L engine.
Everything is running fine, as far as I can tell. I have recently replaced a bad battery and have tested my charging system for any problems that may have caused the old one to go bad.
I disconnected my negative battery cable and, with a voltmeter, tested the loose cable lead with the negative terminal. I got twelve volts from the terminal to the cable. Do I have a short in my charging system?
Old 12-22-2005, 05:42 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
No,
What you DO have is probably a normal drain by Vehicle computer keep alive line, and CD/Radio Presets (memory) and clock..
This is commonly confused by measuring Voltage for Amps..a .03 Drain (which is normal for a Modern vehicle) Will ALWAYS be 12 volts..12 Volts at .03 a will not drain the battery anytime soon..12 volts at 4 amps will kill it in a few hours..
Retest using the AMPS scale, set the meter for the HIGHEST setting (usually 10 amps) and be careful you don't exceed that amount for anytime or you'll damage the meter, (or use a 5 amp fuse on the probe) 0.03 to 0.08 is Normal and acceptable..anything higher, you have a branch circuit draw or bad diode packs in the alternator/regulator.
Doc
Old 12-27-2005, 06:00 PM
Thanks for the word. I'll check for amps later. My truck seems to be running ok at the moment.
Old 12-27-2005, 06:27 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
On bad Diodes...It will..If you Daily drive it. Until you let it set for a specific period of time..then it will drain the battery..unlike a constant branch circuit load..Diodes will do there deed while sitting "Off" and partially charge while driving, not making a "Constant".
Doc
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Charging System Not working rbfpezcore Electrical 8 06-21-2005 06:52 PM
2001 Ford Van Charging System NAIRB Electrical 4 06-09-2005 06:01 PM
GM truck charging system ? outlaw17 Electrical 2 06-03-2005 03:55 PM
Charging system Problems 85 vette Electrical 7 01-02-2005 11:36 PM
