short or long ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2007, 07:35 PM
short or long ??
I am looking at lots of parts for rebuilding my 350 small block, but am finding issues with some of the bolt on things. What is the measurement for a short water pump and a long water pump? I looked at mine now and from block to front of pulley hub was apx 6 inches. HELP!!! Please
Old 08-14-2007, 07:48 PM
If you can put your finger between the pump and the camshaft cover ... it is a long pump.
Old 08-15-2007, 12:12 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Great pic and explanation!!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 08-15-2007, 11:07 AM
re: short or long ??
wow, and thank you very much. The local parts folks are lost in regards to this and to lazy to find out. Mine is short but I am still proud of it.
Thank you for the time and picture
Old 08-15-2007, 02:51 PM
The short pump was standard on the SBC until the late 60's. By 1969 ... most all were long except the Corvette and later the V8 Monzas. Most model early Hot Rods use the short pump. The long one is just too long to fit on a SBC in a 20's to 40's street rod. There are a LOT of dress up pulleys and brackets for SBC's using the short pump.
Old 08-15-2007, 04:07 PM
T-bucket23's Avatar
Wiki Edits: 26
You need to be careful with your timing cover selection as the short pump leaves little room for a thicker timing cover. A lot of the aluminum ones or multi piece ones wont fit with a short pump.
Old 08-15-2007, 04:15 PM
short or long ??
this is all good info due to my not messin round with engines and just Hot Roddin in general for a long time. It's funny how much of the little stuff you forget.
long or short chevy water pump? 97Z28 Engine 10 04-24-2013 09:23 PM
Pulley Change Out Long to Short Water Pump Mule Engine 7 05-25-2007 07:06 AM
350 short block and long blocks? Brian Morency Engine 5 09-16-2004 02:07 AM
Changing T350 short shaft to long shaft Jmark Transmission - Rearend 6 01-17-2004 04:22 PM
The long and the short of it. 57Chevyman Engine 2 02-12-2002 10:46 AM
