-   -   Short and long shaft TH350's.... and extra long too? (http://www.hotrodders.com/forum/short-long-shaft-th350s-extra-long-too-153823.html)
383ram 02-22-2009 02:31 PM
Trying to figure out what applications to look for so i can get a TH350. I see on TCI's website as well as others they list a short (6"), a 9" and a 12" tail shafts. I am a Mopar guy and have had my head stuck in the sand for a long time, but i was always under the impression there was jus a long and short shaft TH350--but all the charts list 3 lengths.
I am trying to find one that has the 9" tailshaft for a 30 11/16" overall length to fit my application. What were these generally put in?
burnt olds 02-22-2009 03:54 PM
chevy trucks 77 for sure
rockbatty 02-22-2009 04:02 PM
turbo 350
Check out full size cars of early to late 70's
Rockbatty
327 / 350 hp 02-22-2009 05:58 PM
Tranny Lengths
HI 383, those came in 76 Caprice that i know of. I scrapped one. 327/350hp
jimfulco 02-22-2009 11:24 PM
The 9" tail was common, if not universal, in Chevy half-ton trucks from '73-'86.
mmerlinn 02-23-2009 09:59 AM
Most trucks and a few large cars.
SSedan64 02-24-2009 09:21 AM
Chevy vans also have the 9" tailhousing.
lg1969 02-24-2009 03:01 PM
I was told from a transmisson repair shop that there two version of the th350. One version is to handle V8's and another version for 6 cylinders motor. They used less clutch packs.
mmerlinn 02-25-2009 02:43 AM
Number of clutch packs never change in any 350. Both drums have clutch packs and there are two more clutch packs in the case itself.
Now if he is referring to the 350 versus the 250, yes, there is one less clutch pack in the 250.
Crosley 02-25-2009 05:50 AM
The member was probably referring the friction plate count in the clutch packs... which were different in lower horse power applications.
:D
mmerlinn 02-27-2009 03:10 AM
:D
Maybe. However, rather than ***-U-ME that is what he meant, I replied to his statement as posted since it is entirely possible that is what he meant.
383ram 02-27-2009 05:08 AM
Thanks for your help guys, i will start the search. I have a 700r4 that needs to be built, but thought if i could find a good working 350 id put that in for now. And being that i have to build a trans crossmember anyhow, i can set it up for both.
