Short to long water pump for early sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2008, 07:18 PM
Is it possible to use a long water pump instead of the short water pump on my 1977 Corvette? I am planning on converting to an electric cooling fan system. Is there more to the short and long pumps other than just their length from the block?
Old 07-18-2008, 08:04 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Thats the only difference that I know of.
Old 07-18-2008, 08:30 PM
You would have to also change pulleys and brackets for the alternator and A/C compressor.
You can do it but I see NO ADVANTAGE to it ...
Why do you want to go from a short to a long ... most folks want to go the other way to gain room at the front of the engine.
Old 07-19-2008, 05:52 AM
streetrodderbn's Avatar
Certifiable Streetrodder
I agree with deuce, If you look at the water pump pulley spacing, there is actually a 3rd measurement or different water pump, just for the vette. Just replace the stocker with a good aftermarket new pump, or your favorite parts house pump with a lifetime guarantee! The hassle of changing all the brackets to get the proper pulley alignment could be maddening in the vette!!
Old 07-19-2008, 06:28 AM
poncho62's Avatar
Wiki Edits: 5
The only advantage I see, is that you get to use a shorter belt on the alternator.........also, easier access to fill PS pump.
The alternator has to go to the other side, different brackets and all different pulleys.
Ontario Rodders
long or short chevy water pump? 97Z28 Engine 10 04-24-2013 09:23 PM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
Extended height SBC water pump DJ3100 Engine 3 06-18-2007 03:12 PM
Water pump. Long or Short Zeater1 Engine 5 07-04-2005 07:09 PM
SBC 350 WATER PUMP pitsen3 Engine 1 01-13-2003 10:02 AM
