Short SBC Single Plane w/Rear Water Ports - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2008, 07:28 AM
Just wondering if anyone else has already tackled this headache. I'm looking for a short carb height SBC single plane intake that also has provisions for rear water ports (3/8" NPTS in the back blocked spots). Something the height of a 2975 Victor JR would be great - that is around 4.580" carb height, but Edelbrock does not make one with ports and it looks like I will be in the distributor hold down flange if I just drill and tap the stock there. This leaves me with finding something that will work or welding in a vertical round slug on a Jr. and then tapping it vertically to clear the distributor hold down.
The fun, the fun. The Super Victor is an inch taller and has the ports - so I could use one of those and then it looks like I could machine 1/2" back off the top of the carb mounting flange to get me somewhat close - just a lot of work to make something happen. Gotta love height restricted applications!
Old 12-29-2008, 08:04 PM
jgh64pkup's Avatar
Last journal entry: new et streets
re: Short SBC Single Plane w/Rear Water Ports
i think the professional products hurricane manifold is the same height as the jr. but also has the water ports in the back i think they're a little cheaper like 60 bucks or you can pick up a polished one for about the same price as the jr.
the website is speedway motors http://www.speedwaymotors.com/High-P...-360,7130.html
or polished is http://www.speedwaymotors.com/High-P...-360,7131.html
super victors also have the rear water ports
Old 12-29-2008, 08:09 PM
Thanks for the link - I ended up solving the problem today - ended up using an older Strip Dominator with some thick intake gaskets to get the ports to match up fairly well to what I had. The distributor hold down was clocked a little more than the Edelbrock so we were able to drill and tap the rear of the intake for water.
Just fyi if anyone stumbles on this thread in the future: The Hurricane measures out almost identical the the standard Super Victor (have both sitting in the shop right now) and they are right about an inch taller than the Jr. I bought a Hurricane last year - port matched and cleaned it all up, and on install found it was about an inch to tall - doh! Oh well, someday it'll be used
Old 12-30-2008, 12:30 PM
jgh64pkup's Avatar
do you want to sell the hurricane i need one
Extended height SBC water pump DJ3100 Engine 3 06-18-2007 03:12 PM
single plane intake or duel plane intake?? CurtisL Engine 10 11-02-2003 03:36 PM
Any SBC single plane intakes that are truly streetable? Blown72Camaro Engine 20 09-28-2003 12:20 AM
Long water pump to short. What's involved? hiimed Engine 4 07-16-2003 07:32 PM
SBC 350 WATER PUMP pitsen3 Engine 1 01-13-2003 10:02 AM
