Short shaft on long shaft tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2010, 11:24 AM
Think I know the answer but before I'm deeper in the money pool I figure I'll be sure. Got a th350 from wrecker today,short shaft, front of housing is not so good. Got a deal on one thats all good but long shaft. Any reason when I come to rebuild I cant make one outta two. That is to say rebuild the long shaft unit yet use the shaft and tail section from short guy? I THINK it makes sense but want to hear from some in the know cause I gotta pay for the long boy,better to know now than after
Old 07-07-2010, 03:23 PM
ericnova72's Avatar
More for Less Racer
Yes, you can make a tail housing and tailshaft switch at the time you rebuild it. Tailshaft is basically the first piece into the case when rebuilding, so you will have to completely gut both cases to get what you want.
Don't forget the speedo gear is on the shaft, make sure to keep the one you want.
Old 07-07-2010, 04:14 PM
Thanks Eric. I knew the shaft was last out,first in and my gut said they'd switch but by God that ol gut of mine has cost me bucks before
Thanks for your input bro.
Ya the speedo gear I usually gotta by knew to match diff anyhoo
long bed into short box ? truckboy61 Body - Exterior 3 01-26-2010 03:22 PM
Short and long shaft TH350's.... and extra long too? 383ram Transmission - Rearend 11 02-27-2009 05:08 AM
SBC - Water Pump Swap - Long to Short Houston54 Engine 7 03-04-2008 07:21 AM
Th 350 Long Shaft What Did It Come In calhoun Transmission - Rearend 5 12-29-2007 12:27 AM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 01:53 PM
