Short valve covers too tall... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2005, 07:22 PM
The 283 in my truck originally came with some super-low rise valve covers with the "Chevrolet" script on it. After it was rebuilt, I of course wanted some chrome ones. I got some tall ones, not that there was any need to, but there's just more chrome to show off. They hit the firewall on the driver's side and wouldnt fit. I took them back and got some short Edelbrock covers, and they fit on alright, but now the column shift linkage won't clear them. Does anybody know of any extra-short stock height chrome valve covers? I don't need any taller than that, it has the stock valvetrain except for the Comp Cams 268 cam.
Old 12-05-2005, 09:49 PM
DHMag's Avatar
ive never heard of any valve cov ers shorter than stock. those factory covers would look niced chromed.
Old 12-05-2005, 10:13 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
look up Mr.Gasket part number 9800
or Summitt racing part ## MRG-9800 .......30 bucks or so .......stock hight, chrome, plain.
Edelbrocks are a little chunky
Old 12-05-2005, 10:18 PM
MI2600's Avatar
Member# 3287
The valve covers hit the shift linkage??? What kind of car is this?
Old 12-05-2005, 11:33 PM
techinspector1's Avatar
Wiki Edits: 326
Scroll to the bottom of this page under "Plating". Contact one of the shops listed and ship your stock covers off to get the treatment.
http://www.stovebolt.com/links/services.htm#plating
Old 12-06-2005, 02:47 PM
Thanks all. BTW, the this is a 1959 Chevrolet Apache truck with a 3 speed column shift trans. It has a 283, which is offset a little toward the driver's side, which makes things around that linkage a little tight. Also, i meant to mean that Edelbrock's short covers are taller than the stock ones.
Old 12-06-2005, 02:55 PM
One more thing, i need a filler hole. There's no hole in the new intake for the stock filler neck. Unless I could put the oil in the drain holes on either end of the head, and then put the covers on, but I dont know how much sense that makes.
Old 12-06-2005, 04:48 PM
I always add oil through the valve cover where my push in breather goes.
Old 12-06-2005, 05:08 PM
oil
Not sure what to do other than tap hole in intake or add oil in draft tube. But you still need a breather and good cross flow air flow in crankcase.
Some of the older aftermarket intakes have the breather hole look on ebay.
I assume your valve covers are solid like original. You need a breather and an exhaust (PCV).
A good hint though. If you take a PCV grommit from a big block it will fit snug in the old draft tube hole in the back of block and you can hook up a pcv valve in back. I have this on my 283 plus a nice chrome oil fill tube for the classic look.
Old 12-06-2005, 05:10 PM
steve t's Avatar
ex biker, now hotrodder
with no oil breather tube, you will need holes in valve covers to let engine breath, so i would not chorme stock covers yet
Old 12-06-2005, 05:42 PM
First I'll probably try the Mr. Gasket covers mentioned earlier. If those don't work, i guess ill do something about the intake manifold. The engine guy plugged the hole in the back of the block with a smaller freeze plug type of thing before it was put in the truck, i guess since at the time we had the tall valve covers with the pvc/breather holes in them on it and it wasnt needed. At that time we didn't know they wouldn't fit against the firewall.
Old 12-06-2005, 07:05 PM
Some aftermarket intakes can be machined for a filler neck, if the manufacturer left a place for it. You can also use a GM PCV adapter in the draft tube hole if you can find one. Try a Corvette resto parts place. Here's a pic:
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Tall valve covers needed? KeithB123 Engine 15 02-03-2004 12:54 AM
302 valve covers? Super Chevy Engine 2 01-13-2004 05:37 PM
need chevy OEM baffled type valve covers TVR383 Engine 8 10-18-2003 05:22 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
