Many businesses don't understand that if you take care of customers they don't forget it! Quote:
Multifuel suggestions can still be useful since you can cut and heat with an alternate fuel to save acetylene. The crusty veterans won't need that of course, but many folks don't think about convenient ways to do that. For example, one can use a single oxygen cylinder and a valved Y-fitting (handier for connecting/disconnecting stuff downstream) along with an acetylene welding torch and a propane cutting torch or rosebud setup. No second oxy cylinder rental, no overdraw on small acetylene cylinders for rosebud work, less torch swapping, and money saved for other things. Google "Western Enterprises" along with the general fitting name and it's often quicker than using their catalog. They rule the roost and their brass fittings are widely available online. If you don't like your LWS or are too far away it's a good way to go. If you LIKE your LWS, showing up with the printed Western page for reference saves them looking it up. Informed customers are easier to serve. I prefer to do the research and let my LWS do the ordering. Everybody is happy. The hardcore gas welders might consider haunting Craigslist for more acetylene cylinders to facilitate hoarding. You can get more acetylene cylinders before running your current batch empty. When hunting used cylinders: Get the NAME off the neck ring AND the sticker. (I take digital pics when useful.) Over the last century there have been many welding gas suppliers who were later consumed by industry consolidation. If your local supplier won't exchange the cylinder it's useless. (I would keep 'em for friends who aren't local if they were free.) Call supplier to see if they'll swap. I don't do this where seller can listen in. Know in advance if the supplier actually cares about hydro dates or what hydro will cost. If you have a selection of suppliers, know their different exchange policies. All this VARIES by region and individual supplier policy. Assume nothing. Arc marks and other damage can condemn a cylinder easily. There are plenty of UGLY old acetylene cylinders, but know disqualifying damage. Since J&M is here, he might post his specific policies to educate the group. There are LOTS of good owner-sized cylinders in garages and barns out there which can be exchanged. If you have buddies with cylinder contracts, they may be able to run your exchange cylinders through their shop. Contract prices can be MUCH lower than guy-off-the-street retail. Last edited by 1930case; 04-09-2011 at 08:26 AM. |
All good suggestions for those who need Acetylene. I personally have used LP for years for cutting and mostly just use Acetylene to weld with and occasionally with a scarfing tip. For many years when I ran my shop I also used LP for most cutting chores because of the major cost savings so I mostly was just trying to get this discussion back to the main topic of "what do we use now if we can't get Acetylene"? As far as which alternate gas to use then it must be remembered that home shops are going to have mostly different requirements than an industrial setting. My point from the start has been there is no point in recommending someone go out and spend money for a conversion (if required) for a specialty gas when LP is so easy to find and so inexpensive to use. If there is an advantage to a particular gas vs LP that makes the extra cost and bother worth it then lets discuss that but honestly what benefits, for the home shop, could there be? All I am saying is why have someone spend money for regulators, etc and then hunt down the fuel only to find that they can do the same thing with LP which can be found anywhere? Been a lot of good info for us "Crusty veterans" and it has been quite interesting but the real issue is for the home shop and WHICH alternate gas to use! My honest opinion is that LP is by far the best choice for the home shop. Reasons are, It's probably the least cost both to set up and use. With most torches it will require a simple tip change. Widely available and easy to get anywhere. Cuts cleanly and handles heating and brazing chores easily. Ok now any suggestions for a better gas alternative and reasons why? |
acetylene requalification info. its very general and deals with test dates mainly. and the CGA pamphlet you need to see is C-13 but i cant find it for free anywhere. maybe someone else will have some better luck.
https://hazmatonline.phmsa.dot.gov/s...s/safe4-01.pdf |
Since welding with alternate gases ain't happening, it becomes a question of cutting and brazing.
Remember if you want more preheat when cutting, just run a bigger tip and hold the torch back enough to get a clean kerf. Many new cutters don't know that even on warm days a preheat pass over thick metal makes for a much nicer cut. Tip experimentation for the hobbyist can get expensive, so snag a pile of them cheap off Fleabay or similar. You can also run the American Torch Tip Multi-Use adapter with a variety of inexpensive tips for different gases. I get mine from ATL Welding Supplies online. If you have a vintage torch that's a hassle to get tips for, these can help. My Smith LC and Meco Cutmaster are back in use since I found out about them. Any propylene fans out there? I've never used it or run into someone with practice using it. http://www.weldingtipsandtricks.com/...l-cutting.html Last edited by 1930case; 04-09-2011 at 01:58 PM. |
Not a fan of the stuff for sure but I did use quite a bit of it back in the 80's before I switched to LP. It has the advantage of LP in that most torches require only a simple tip change and it is hotter. It also seemed to be better in an outdoor situation in really cold weather when a large demand such as a heating tip was required. It has no disadvantage to LP and as I said it is hotter if that is a concern, for a home shop it will not be, and it is widely available at most welding gas suppliers. My suggestion on Propylene would be to base the decision on cost and availability because other than that there will be little difference between it and LP in a home shop. |
Straight and to the point, Thank you!
The largest hand cutting torches run propane, and the steel industry can afford it's choice of gases:
Check the thickness range specs for the cutting nozzles! http://products.esabna.com/EN/home/g...utting_nozzles |
That's been my point about using LP and for the home shop I just can't think of anything better. As far as brazing /welding, it does work for brazing but not as well as Acetylene due to it not being as hot but with the right tip and a bit of patience it does work. Welding is just not going to happen period! Even with enough heat to melt the weld puddle it still will not work because the flame chemistry is all wrong and all it will do is make a mess. |
Here's a guy with the right brazing tips, patience, and pics of work plus a bend test:
http://www.chaski.com/homemachinist/...p?f=12&t=87931 I used to braze steel rule fabric cutting dies for a stuffed toy company. (Eden Toys, Jersey City, I'm ancient!) We used acetylene because it was what the company had. They would take some impressive force on the cutting press (they work like cookie cutters for fabric) and the normal failure point was when the steel bent and twisted. Heat it, beat it straight, braze it, and put it back back to work cutting more toy skins. Brazing is tough, flexible, EASY to learn, and you can wash off the brazing filler with a torch without trashing the parent metal. Last edited by 1930case; 04-11-2011 at 10:49 AM. |
We may be heading off in a different direction here but that is an excellent point! Brazing is a very often mis-understood method of repair and too many people just think of it as a weak patch instead of the strong joint it is. Proper Brazing with a good Bronze filler is a lot stronger than most people give it credit for and it is often passed up for that reason when it actually might be the better choice depending on the job at hand. |
Brazing can be an opportunistic use of available equipment.
Gearhead buys propane torch for inexpensive cutting, needs to join something unexpected, has brazing (which can be done with the preheat flame of a cutting torch as well as a combo torch tip) in their "mental toolbox", solves problem. Multiply "stuff you own" by "what that stuff can do" and that can be quite a bit of scope. Extra points for not requiring electricity. |
| Recent Garage - Tools posts with photos |
| With Crane gone will there be a cam/lifter shortage? | eric32 | Hotrodding Basics | 14 | 04-15-2011 10:43 AM |
| Canada shortage! | BarryK | Hotrodders' Lounge | 11 | 12-12-2004 07:50 PM |
| turn signal shortage | texasfinest1 | Electrical | 2 | 09-16-2004 02:13 PM |
| Lifter shortage to end soon | BOBCRMAN@aol.com | Engine | 22 | 01-25-2003 04:33 AM |
| Lifter shortage | willys36@aol.com | Engine | 11 | 10-14-2002 08:13 AM |
