Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Shorten Mustang II control arms ???
Old 04-09-2011, 09:06 AM
454 Rattler's Avatar
454 Rattler 454 Rattler is offline
NEVER SATISFIED !!
[QUOTE=aosborn]Typically the steering arms are wider at the end where the hole is, if you shorten them will there be enough material to re drill the hole. Are you drilling a tapered hole to accept the stock tie rod end? Shortening the steering arm will quicken up the steering, is that what you are after?
Yes, you can elongate the upper control arm adjustment slots, but if you are lengthening them inboard, make sure the control arm doesn't hit the top hat in droop.
Andy[/QUOTE
I didn't plan on re-drilling the steering arms or shortening them because they are part of the spindle.
I only want to shorten the upper and lower control arms (A frames) for tire clearance.
Is there any reason that I shouldn't try it ?
