Shortening pinion shaft RandP steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2007, 09:35 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
I just installed a Flaming River rack, and the pinion shaft needs to be shortened and re-splined.
Can some one tell me the procedure to remove the pinion shaft, so I can get it to a machinist.
Thanks,
Bob
Old 02-02-2007, 08:52 PM
AngliaBob's Avatar
Bump...
There has to be someone who can give me the basic instructions to remove the pinion/steering shaft...
Thanks
Bob
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 09:02 PM
Pinion Angle? Again? oldskools10 Transmission - Rearend 7 01-27-2007 01:48 PM
Axle Housing Install - Pinion Angle Help leejoy Transmission - Rearend 3 01-08-2007 02:06 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 07:58 AM
cure for worn steering shaft? cboy Suspension - Brakes - Steering 2 04-07-2004 09:21 AM
