Shortest SBC water pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2009, 07:14 AM
What is the shortest chevy small block water pump? Part number year excetera. It has to have the old style V-belt rotation? I could take time to look it up but I know some body up here knows this right off the top of their head.
I'm helping a buddy put a small block chevy in a 37 ford sedan. We're on a tight, tight budjet! We have the engine in the car and it looks like it might work with the stock radiator if we can find a short pump. Not gonna serpentine system or have AC for right now but we are gonna use the cavalier power steering pump. No problem with any of that I just need some info on the water pump.
And if you have a minute see if any of you can help this guy with his 85 chevy truck
*help* hopefully i didnt fry everything
Read my post there I think all he did was burn the ground straps or fry the little fuse strap on the firewall.
Thanks in advance.
Chris
Old 02-07-2009, 07:37 AM
poncho62's Avatar
Wiki Edits: 5
All V8 Chevys before 69 had the short pump.........Alternator is on the drivers side beside the valve cover. Go to a scrap yard and get ALL the pulleys and brackets off of one car, that is your best bet.
Old 02-08-2009, 01:49 AM
SSedan64's Avatar
WATER PUMP ID:
http://www.chevytech.com/2c41o1.html
SHORT vs LONG WATER PUMPS:
http://www.chevytech.com/2c41o2.html
Old 02-08-2009, 08:03 AM
302 Z28's Avatar
Early Corvette.
Vince
Old 02-09-2009, 05:39 PM
Originally Posted by SSedan64
Thank you for the links SSedan64. Very informative and of course they are now saved in my favorites.
Old 02-10-2009, 03:44 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Don't expect miracles... the length of the water pump is one thing, but the pulleys tend to put the accessories almost as far forward as they do with a long pump.
The short pump might be 7/8" shorter over all, but the crank pulley, water pump pulley, and accessories are only about 1/8" different between the two drives.
Old 02-10-2009, 04:39 PM
The stock 37 radiator is angled back so the waterpump will be the tight spot. If the altenator is a problem, you will need a bottom mount altenator bracket setup.
I have not put a SBC in a 37 but there are a ton of guys out there that have done it.
High flow water pump for SBC 350 75gmck25 Engine 7 05-22-2007 04:42 PM
Electric water pump, what gpm? New fan? 84Z Engine 4 02-01-2007 06:30 PM
90s SBC Power Steering Pump pulley Removal Help Mustangsaly Engine 12 10-08-2006 07:00 PM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 10:34 AM
