Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Shorty Powerglide in a flatbottom V-drive boat questions
Old 01-31-2013, 07:02 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
In boat applications usually reverse and park are blocked out.
Sell the trans brake v-body as suggested. Buy or build the needed v-body. It is safer and better.
the v-body you have is called a no button back up trans brake. They generally are slower release of the trans brake than a fluid release pro-tree v-body
Main line pressure is controlled via PR spring and the size of the boost valve in the v-body too
The Following User Says Thank You to Crosley For This Useful Post:
BadBehavior (02-05-2013)
