shorty spark plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2011, 05:17 PM
shorty spark plugs
After exhaustive searching,I didn't come up with much. I run R45TS plugs, and tried to find an equivalent,in a shorter plug, but not much luck, other than Acell. Anyone have any suggestions? Those plug heat shields(boots) would work, but would be resting on the header tubes, which would shorten the lifespan of them. I see Taylor makes an aluminum cap that fits over the boot, wonder if those might be a solution?
Old 02-28-2011, 05:34 PM
spinn's Avatar
Accel makes a standard thread shorty plug. That it ?
There are 1/2" header Flange extension that use flat head screws, then bolt header to the flange extension. Might help with heat too.
There are the old school 30's plug ends that are brass, they might work. You have to unscrew the plug tip , get it the bare fine threads, and connect the secondary wire with a nut.
Old 02-28-2011, 06:55 PM
Delco rapidfires seem to be shorter than regular Delco's but not as short as a
Accell shorty also try an equvilent NGK might be shorter too.
Old 03-02-2011, 07:28 PM
Rhansen's Avatar
Footbraker
I've found the NGK's to be almost as short as the accel shorty plugs.
Autolite "AR" series plugs are supposed to be short as well but I have yet to try them.
sbc shorty header plugs stea Engine 9 06-05-2011 01:12 PM
Any good "shorty" spark plugs besides Accel? Cousin_Joe Engine 13 04-04-2008 08:08 AM
Accel shorty plugs- Any good? Blue68Camaro Engine 10 10-07-2007 09:48 AM
Shorty Spark Plugs for Vortec Heads?? acr Engine 1 05-13-2005 09:23 PM
Shorty Header Plugs Bluepen Engine 4 05-02-2005 06:28 AM
