A shot of ackerman anyone? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2006, 09:43 PM
Thanks for reading....
I'm ready to start mounting my custom front clip and have a question about ackerman. I'm satisfied with my roll-centers, instant centers, anti-dive and flexibility in bumpsteer adustment, but can't decide how much ackerman I should be trying to build in. All of my experience in circle track racing tells me that I don't need much.....we only run 1/8 of a DEGREE (out) per 10 degrees of steering on our current setup. I don't think that is an acceptable amount for the street. What is? My current plan (cad drawn) has me with about 3 degrees in 20 degrees of steering.....any insight would be appreciated.
Phil
Old 02-08-2006, 11:28 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
According to Maurice Olley, Ackerman steering was initially a design feature to minimize the disruption of gravel on the driveways of early wealthy motorcar owners. It is certainly not a requisite in a modern design. Formula One cars often use negative Ackerman, simply because of the different slip angle requirements of the inside and outside tires.
http://home.earthlink.net/~whshope
Old 02-09-2006, 01:04 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
You'd be surprised at how many cars on the road today survive quite fine with a lot of reverse ackerman. Don't stress over it. One of the nicer handling cars (the 4th-gen F-body) survives with a front-steer reverse ackerman quite well.
You can set it to neutral using the rear axle centerline, but honestly I wouldn't worry about it.
sand vs shot in a shot bag antiquecar Body - Exterior 9 03-17-2005 09:26 AM
Shot Peening - Interesting Read dbuff Engine 0 09-02-2004 12:43 PM
My Hot Rod, is now a SHOT ROD! bullheimer Hotrodders' Lounge 3 04-15-2004 10:25 AM
one shot over midcoat 6speedwagon Body - Exterior 6 03-08-2004 08:09 AM
top shot nitrous systems cuda66 Engine 2 03-01-2003 06:24 PM
