Should 4 link bars be parrallel to ground at ride height? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2005, 04:03 PM
Last journal entry: Latest picture
I checked the FAQ's, but no history on this topic. I'm scratch building my 4 link rear w/ panhard to go into a 28 Dodge with an 8 3/4. Any other geometry help on the 4 link would be appreciated.Thanks. Dan
Old 03-03-2005, 05:47 PM
cboy's Avatar
Last journal entry: Finished
hemi,
If you use the search function or knowledge base you will find tons of info re: your 4-bar setup.
Always learning...and sharing what I've learned.
Old 03-03-2005, 06:06 PM
Thanks Cboy, But....
I re-did a search, and there's lots of info for triangulated 4 bar, or oval track, or drag race etc..... This is for a street rod , using a parrallel 4 bar with panhard. I need to know how the lengths of the bars are figured out, as well as if they have to be parrallel to ground etc... Thanks Dan.
Old 03-03-2005, 06:21 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
As cboy pointed out, there's tons of setup info for the 4link available on this forum. Don't be discouraged because the reference seems to be to a triangulated 4link. The same angle principles, when viewed from the side of the car, apply for both cases.
As you'll see, when you view these threads, setting all 4 links parallel to the ground will result in extreme squat. On the plus side, there will be no binding as you corner during street driving. If, however, you keep the links parallel to each other, but at an angle, to the track surface, with a tangent equal to the CG height divided by the wheelbase, you'll have no squat or rise AND there'll be no binding during cornering. More work is required if you want to eliminate the tendency for the driveshaft torque to unload the right rear.
Ride height delimma wally8 Suspension - Brakes - Steering 8 01-03-2005 02:15 AM
Increasing Ride Height Slightly - what are my options? hduff Suspension - Brakes - Steering 8 10-19-2004 07:44 PM
Ride height 1937 ford pickup magnum2u Suspension - Brakes - Steering 0 08-21-2004 05:02 PM
Air Ride Technologies 4 Link Cowtown Punk Suspension - Brakes - Steering 1 07-30-2004 07:17 PM
raising rear ride height 67_Deuce Suspension - Brakes - Steering 5 01-18-2003 10:19 PM
