Should have done it right the first time - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 09:59 PM
sedanbob's Avatar
I took the '33 sedan for a short drive today - on the highway crossing the Mississippi river, the engine sputtered several times. When I let off the gas, and started coasting to the shoulder of the road (once I was off the bridge), the engine kept running. Seemed like it ran ok until I gave it more throttle. Symptoms seemed like a clogged fuel filter. I have one of those small glass filters. After I first got the car running, that filter clogged with junk that was apparently in the new fuel line. Thought it was the same thing again.
My upholstery shop wasn't far, so I headed there to borrow tools to swap out the filter. Engine must have died 10 times on the way. After struggling in hot tight confines of my '33s engine bay, I got the filter out, only to find that it was still pretty clean! Not the problem.
I checked the lead going to the coil in the HEI - it was loose. The only reason it ran at all was the wire was pretty stiff so it was held in place - sort of. Pushed it back on and headed home (after replacing the fuel filter). When I got home and checked, the lead was already coming loose again!
Rewind back to when I wired the car... I knew the HEI coil and tach leads used flat blade clips, so I crimped and soldered them on the leads then covered them with shrink tube - then I found the plastic clip covers included with my wiring harness, specifically for those connections. Since I already had clips on the wires, I decided I wouldn't bother with the plastic clip covers...dumb! There is a reason those clip covers lock onto the HEI housing... so they don't come loose like mine did!
So now I have the correct clip covers on those leads, like I should have done to do it right the first time! Lesson learned.
Old 04-04-2013, 10:30 PM
The mobile view is crap
There's never time to do it right the first time but there's always time to redo it.
Old 04-04-2013, 10:33 PM
sedanbob's Avatar
I was lucky my redo wasn't by the side of the highway!
Old 04-05-2013, 07:58 AM
Banned
this is how we all become better, we screw up and fix it, now we all know to use the clips instead of throwing them on the bench. Glad to hear she is running fine now, i know it is the worst when running a super nice rod like yours and you have trouble for all on the road to see.
Old 04-05-2013, 08:14 AM
Im glad you got it fixed safely Bob and, just as importantly I'd like to point out its good to see a nice car get driven on the backroads. More and more of my customers are building trailer queens they trailer to events and drive on cruises then back in the trailer. I even have customers who are afraid to drive their car far because its too finicky or it is prone to overheating
Old 04-05-2013, 09:09 AM
sedanbob's Avatar
I couldn't stand building it and not driving it! Today I will be adding a few items to the toolbox I keep behind the back seat.
Old 04-05-2013, 09:46 AM
454 Rattler's Avatar
NEVER SATISFIED !!
I'm glad to hear that you've put the sedan on the road. I would hate to know it was a trailer queen.
That little problen reminds me to check, check, and check again. I'm always worried about breaking down on the side of the road. It takes all the fun out of even having a street rod.
Your story reminds me....I found a nut about to fall off of the control arm on the Mustang II frontend of my 36 Ford. I guess it's a good thing we still have some snow on the roads around here.
Well, good luck with the rest of your shakedown runs on that beautiful sedan.
454 RATTLER
Old 04-05-2013, 10:29 AM
sedanbob's Avatar
454 Rattler - good catch! That could have been ugly! That's my job for today - go over everything and make sure it's all tight.
Old 04-05-2013, 03:36 PM
Banned
bean counters don't spend money for nothing.. dad always said if the part got past the beancounters it was needed.. or it not be there..
nice that it was an easy fix..
Old 04-05-2013, 06:16 PM
Old Fool's Avatar
Alls well that ends well !
Glad to hear you weren't stranded @ the middle of the bridge
Old 04-05-2013, 09:16 PM
sedanbob's Avatar
I was really lucky that I was able to get somewhere I could borrow tools. I had to take the hood side off to get to the fuel filter (when I thought that was the problem), and did not have an allen wrench with me... I do now! I spent the afternoon double checking everything I could think of, and double checking the contents of my on-board toolbox!
Sewing machine comparison-long time seamstress, 1st time upholsterer - Singers altheapdx Interior 8 09-06-2012 12:27 AM
converting transfer case np203 from part time back to full time blade12376 Transmission - Rearend 1 12-05-2011 08:53 PM
Interesting time test I did on fuel vs time used for my commute. MARTINSR Off-Topic 5 08-27-2010 11:37 AM
long time reader, 1st time user brandon624 Introduce Yourself 1 03-13-2006 05:16 AM
1st time caller, long time listener 56Cameo Introduce Yourself 1 07-19-2004 01:06 PM
