Should I add weight to door shells to simulate glass etc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2007, 12:02 AM
Ripped's Avatar
Last journal entry: First RoadCourse Video
I finally got my lower hinge pin kit (even though my hinges are pretty tight) I will rebuild them, then mount the doors back on the car for blocking and aligning body lines.
Should I add weight to the inside of the door shells to simulate what they will weigh, once all the glass etc is added?
Old 03-04-2007, 12:44 AM
bluestang67's Avatar
Last journal entry: rear end detail
i would say no. The amount of weight is not that bad from windows and regs. The pins and hinges were designed to hold door where it is set and adjusted . The door shell is reinforced to hold the weight.
I took the glass out after door alignment for paint and gap didn't change at all on my coupe. They have the same doors.
Old 03-04-2007, 10:07 AM
Custom builder and painter
Last journal entry: Another test fit of the axle
I just did this on a 88 chevy pickup.. there is so much in those doors that id did change the bodyline slightly.
Old 03-04-2007, 02:06 PM
I would put the weight back in before sanding, also you can tweak the body in some cases by tightening the body mounts down .
Rob
http://www.1969supersport.com/
Old 03-04-2007, 04:36 PM
adtkart@aol.com
Door adjustments should always be made with all hardware in/on them. It will make a difference, on some cars more than others.
Aaron
Old 03-05-2007, 05:42 AM
I always put 25-30 lbs in the doors to simulate the weight of the internal parts, it sometimes makes a big difference. Sandbags work well. I do think those mustang doors are fairly stout though and you might not see any change at all.
window install Jzarczyn Body - Exterior 10 01-24-2009 11:02 PM
windshields bill66di Body - Exterior 15 07-31-2004 07:31 AM
@#$%&* Glass bentwings Body - Exterior 3 12-29-2003 12:18 AM
door glass fred56 Interior 4 10-22-2003 09:40 PM
car still WHEEL HOPS why???? tyson Transmission - Rearend 19 08-11-2003 11:28 AM
