Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Should I add weight to door shells to simulate glass etc?
Old 03-04-2007, 01:44 AM
bluestang67's Avatar
bluestang67 bluestang67 is offline
Last journal entry: rear end detail
i would say no. The amount of weight is not that bad from windows and regs. The pins and hinges were designed to hold door where it is set and adjusted . The door shell is reinforced to hold the weight.
I took the glass out after door alignment for paint and gap didn't change at all on my coupe. They have the same doors.
