My best guess is a clogged oil gallery to the top end in that engine...
Probably the parts alone are worth 100 soo if a fellow was to have the block and heads tanked and cleaned you may have a good start.. just my thoughts.. OMT
If you haven`t checked the heads casting numbers, and there factory 1994 heads there not vortecs, the name Vortec was used since the 80`s as just a name, vortec heads came along in 1996.
There could be several reasons why it had no oil pressure to the top end, if the engine was just primed, sometimes it takes a while before it makes it to the top end. |
Thanks for the Vortec info. Since they are not Vortec, they would fit my 85ish 350that I'm running right now. So if the engine is trash I should still end up with a nice set if heads.
