Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Should I buy this locked up 60gal. compressor?
Old 06-14-2008, 05:58 PM
oldred oldred is offline
If you can get it for $100 or so then buy a pump at HF for about $90 for the 3 HP version you should be OK. You are right you could buy that thing new for about $400. HF also has a bigger V-type pump that is for 5 HP or more but you could slow it down a bit and it should work fine with your 3 1/2 Horse power 7 HP motor.
