Originally Posted by jaguarxk120
Porter Cable lists two 60gl models. One cast iron pump and one aluminum pump. Both single stage pumps. If he can get the unit for nothing or next to nothing and replace the pump with a two stage cast iron pump he'll have a good compressor that should last for years. TF
True but that 7 "peak" HP motor is really only about 3 to 3 1/2 real HP so powering most two stage pumps with it may be a problem, the ones he would likely find anyway would require at least 5 HP. When you get into the two stage units the ratings are generally closer to fact and as such will require a motor with some real power and not that "peak HP" BS. You will then be looking at a motor with at least 23 AMPs or more and with a much larger shaft than those small over rated motors. Basically if he were to use a two stage pump about the only thing he would be able to use from the outfit as it is would be the tank.
