Should I buy a new compressor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2012, 04:18 PM
Wanted to get everyones opinion which I should do. I have a 80 gal 5hp compressor at home that I'm thinking about using. It is an older compressor, probably early 70's, manufacturer is Wayne. It had a 3 phase motor on it already so that won't work for my home electrical. Here is my questioning should I buy a new single phase motor for the compressor for around $400 and have it wired or get a new compressor? As far as I know the compressor was in working order and the oil and everything else looked good on the compressor. I plan on using it for some bodywork at home, using a d/a, maybe some priming, possible painting. I also have a extra 60 gallon air tank that I'll pipe with the compressor. Money wise it would be cheaper to use what I have I didn't have to pay for the compressor or tank, obviously I'll be spending $1,000 + for a new quality compressor.
Old 08-19-2012, 05:37 PM
Wiki Edits: 27
bigger motor ?
My experience is that when you switch to a single phase motor you will need more HP like go up to a 7 single phase. and using a bigger tank can over heat the pump and motor, they are rated for a duty cycle. and need a rest, A single phase rotory converter to power the 3 phase would probably cost more than a new compressor, I have a capacitator converter on my Milling machine and end up with 2/3 of the rater power, It wont run it full speed full, load.
Old 08-21-2012, 09:57 AM
Old Fool's Avatar
I suggest you find a used 3phase 8+ hp electric motor and use it for a converter.
Spin the 8 hp with a drill motor to start it spinning, the rest is all magic and your 5 hp will run fine.
You should be able to accomplish this for less than $100.
Duty rating has nothing to do with tank size, it is how long the motor runs as compared to how long it rests in a given time period.
Use of air tools or paint guns may use enough air the compressor will not be able to get ahead and shut off, that is a 100% duty demand.
example of duty cycle:
8 minutes on, 2 minutes off = 80% duty cycle
10 minutes on, 0 minutes off = 100% duty cycle
To all the electrical experts, lets not get into a pissing contest about phase converting and efficiency. For the large majority of users a simple converter as suggested works in 1000's of applications daily and will work fine for the OP.
Old 08-27-2012, 06:42 AM
deadbodyman's Avatar
Wiki Edits: 11
I've heard of this before ,how exactly does this work and how do you hook it all up? why 8 hp....
Old 09-08-2012, 07:26 AM
Simply using another 3 phase motor for a phase converter won't work very well if at all, especially for a high start load like a compressor motor! Three phase converters using another motor are very common and work quite well but they must be paired with a large capacitor bank to work properly, these converters can be quite expensive (one big enough for 7 HP will be around $800 to $1,000) so just to run one compressor it's probably not a good option. Trying to run a high start load by using just a second three phase motor is usually just an exercise in futility and at worst could smoke the compressor motor!
Here's a schematic for a common design,
Figure 1
The capacitors can be eliminated for a simpler design but they only work for light start loads and would be very problematical for something like a compressor which is almost always a very high start load situation.
Old 09-08-2012, 02:59 PM
Old Fool's Avatar
Figure 1
Aren't the old Wayne air compressors a mechanical unloader type and do not require high starting currernt
Old 09-08-2012, 03:10 PM
Old Fool's Avatar
Hey DBM, set down the 6 pack, get up off your lazy *** and go clean out your mailbox! How in the hell can I send you mail when it is stuffed full?
Old 09-08-2012, 03:24 PM
Almost all air compressors (except for the really small "tire pumper" units) have an unloader system otherwise the load would be too high even with a capacitor start, some are mechanical and some are a simple bleed-off system connected to the switch but they all serve the same purpose. An unloaded compressor is still a huge load at start-up due to the mass and inertia encountered when the motor suddenly kicks on and attempts to start all that stationary weight spinning. A simple unassisted motor type phase converter could work for something like a table or band saw or other very light start load if it's sized properly but those capacitor banks are needed for most applications.
Should I buy this locked up 60gal. compressor? weirdbeard Garage - Tools 32 06-20-2008 08:40 PM
What new compressor/welder to buy MustBnuts Garage - Tools 24 09-16-2006 08:22 AM
Help me buy my 1st compressor shyne13 Body - Exterior 5 05-21-2006 11:47 AM
should I buy this compressor? rlackey Garage - Tools 13 04-14-2005 01:27 AM
Did I buy a P.O.S. Compressor? Gearhead forever Garage - Tools 3 02-05-2005 08:20 AM
