Should I buy this tranny? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2007, 10:23 PM
Knows everything about nothing
Last journal entry: Ever forward
I have an opportunity to buy a TH400 for $50. Reverse is out and it slips slightly in drive. Not sure which gear exactly tho.
It's currently in a 4WD truck, and if purchased, will be going into a RWD. Am I correct to assume that I will need to change tailshafts?
I do have a TH350 that has been built to handle up to 500hp (not sure about tq) with 5000 miles on it. I pulled the pan, and found about 1/8 inch of brass/copper??? "paste" covering the bottom of the pan. I will need to switch this to a 6" tailshaft. It currently has a 9".
What to do? The motor that will be sitting in front will be a 400 SBC running around 450hp and 475-500tq (guesstimate)
Old 11-22-2007, 11:11 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Both transmissions need to be
rebuilt, I think I would opt for the
350, isn't your frame drilled to
move the cross member forward?
Yes to the 400 tail-shaft question.
Good luck,
rich
Old 11-22-2007, 11:23 PM
Then I would need driveshaft modifications. I think it's a solid plan. I need to tear it apart to change tailshafts anyway so a 350 rebuild would make the most sense.
Thanks for the input!
Old 11-23-2007, 12:31 AM
Hi,
When we had the salvage yard I would
separate the drive shafts by mfg. gm, ford, chrys,
that allowed customers to find the correct length
some needed the yoke changed, a five minute job
I sold them for $15.
Take care,
rich
!993 T-Bird Tranny Re-build Mike in Canada Transmission - Rearend 8 06-29-2007 07:09 PM
2004R tranny sotxpanrider Transmission - Rearend 0 05-20-2006 08:49 PM
Tranny update/Torque converter question RObs71Nova Transmission - Rearend 5 12-16-2004 09:37 AM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 06:10 PM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
