Should I charge the AC system before first start - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2013, 11:24 AM
Hi,
I just rebuilt my first engine. Everything is in and ready to be started.
I'm wondering if I need to charge the AC before the first start. My concern is that if I messed up on something then I'll have pull it back out and redo something. This will involve having to drain the AC charge which can turn into a drawn out issue. Will I damage the compressor if I run it dry for 1/2 hour.
Thanks
Old 03-18-2013, 11:32 AM
33Willys77's Avatar
Just dont have the pump wire connected - then it wont turn on. What vehicle do you have? Some have a low limit switch that will not allow it to come on too.
The Following User Says Thank You to 33Willys77 For This Useful Post:
Infinite Monkeys (03-18-2013)
Old 03-18-2013, 12:33 PM
spinn's Avatar
I get the same people pulling in my driveway every summer. My ac doesn't work " I think the compressor is shot" . Then you hook up the refrigerant and, the instant you crack the bottle it switches on.
Sometimes the engine is squealing and they tell you, the engine through a bearing. You take a listen underneath, and it is the AC tensioner pulley bearing.
On start up it is not going to be On. Break the engine in first.
The Following User Says Thank You to spinn For This Useful Post:
Old 03-18-2013, 02:40 PM
Banned
Originally Posted by Infinite Monkeys View Post
Hi,
Thanks
1) the compressor doesn't spin unless the clutch is ingauged..
in otherwords unless you have the a/c on OR the defrozer on. it will not cycle the clutch..
and NO don't charge it untill you break it in and are sure you are good to go..
The Following User Says Thank You to gearheadslife For This Useful Post:
Old 03-18-2013, 02:41 PM
Thanks guys. I appreciate the help.
Old 03-19-2013, 06:55 AM
I would just like to add something about the oil in the compressor. Before you go any further, you need to see how much oil is in it. Some come with oil and some do not. Each system requires a specific amount of oil. Dont just dump some in. If you do not have any idea how much oil is in there then you need to remove the compressor, take out the fill plug and drain it upside down until it is empty. The refilled it with the precise amount and correct type of oil.
The Following User Says Thank You to JOHNSHENOUDA For This Useful Post:
Infinite Monkeys (03-19-2013)
no charge weekend warrior Electrical 1 10-05-2010 11:15 AM
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 07:34 PM
monte carlo charge system wedgieman Electrical 1 11-03-2008 09:28 AM
Super charge/Turbo charge Meka Engine 8 11-24-2003 06:33 PM
Turbo charge or super charge for a small block olds Andrew7dg Engine 2 11-12-2002 11:23 AM
