Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Should i do the GULDSTRANG MOD
Old 06-01-2009, 06:57 PM
moretork's Avatar
moretork moretork is offline
Cleaning up and welding where the factory left off certainly doesn't hurt. As far as locating the control arm mounting point rearward, I'm planning to use an offset mounting shaft (1/8") which will help get the 4 degree pos. caster I'm looking for. Of course, if you use aftermarket control arms they have extra caster built in....
