Originally Posted by mudbog42
I think its the 170, I decoded the vin and thats what it said the car came with
if it is a 170, that's not the best to start with, but not the worst.. getting the new cylinder head for $1,500, milling it to bump the compression.. first obstable being the no longer available .025 compressed head gasket ( have to mill head .025 right off the bat ). so once that's done a .045 gasket will render the factory comp ratio ( actully just under ).. you can get the comp up to 10:1, still run pump gas. with the alloy head, 10:1 comp ratio, electronic ignition, 2bbl carb. seems 150 HP is possible, and that would make the engine respectable. but if you can find a 200, it will swap right in
